Greetings
If I use the Drafts extension and highlight text containing multiple paragraphs, the result ignores paragraphs and instead runs the text together.
Is there a way to retain the carriage returns or line feeds between paragraphs?
Greetings
Is that in Google Chrome?
Now that you point it out - yes, it happens in Chrome. It works fine in Safari.
Is there a way to fix that in Chrome?
Can you try in Terminal:
defaults write com.pilotmoon.popclip DeepCapture -bool YES
then Quit and restart PopClip.
Should sort it. PopClip will now use the “pasteboard grab” method always, instead of reading from the Accessibility API. Unfortunately Chrome has a bug, it omits line breaks when reading text from Accessibilty API.
I’ll try and see if I can work around this more elegantly.
