Edge Browser Not Working
Hello, using OSX26.3, Popclip 2025.9.2
When I try to Google Maps, search all I get is a new (Edge) browser tab without it going to the Google Maps.
Works fine in Safari.
Hello, some follow-up information.
Extensions, Search and Google Maps, work on the first attempt but then do not subsequently work in Edge.
All extensions tested work fine in Safari.
Thanks.
Hello, further update.
Popclip works fine in Edge incognito window, no issues.
Still having the same issue, Popclip opens a Edge tab but nothing happens, with Edge in ‘normal’ mode.
Thanks.
Me too
Update.
I have it working again in Edge. I turned Settings > Privacy & Security > Automation off for Popclip>Edge.
THANK YOU. That fixed it; though I don’t know how you found that.
