Can the extension be amended to include Audible Canada (https://www.audible.ca) as a selection
That’s done! You’ll need to redownload from Audible — PopClip Extensions
Welcome to the forum @mjjebb
Hello Nick - Thanks for your speedy attention. However, could not make it work. I am on Mac OS 12.2. I deleted the original extension and reinstalled it from the link you provided. The drop-down list still did not include audible.ca. I don’t know anything about the coding you use - However, I did notice from viewing your code that you did include “audible.ca” in your array along with the others ?? I also reinstalled it from the “PopClip Extensions” with the same result. I appreciate your efforts and thanks.
I’m sorry, I did not update it properly on the website. Try again now, it ought to work.
It worked - Thanks a million
