I have been using PopClip for a very long time and lately I have only been disappointed in this program. Since the most popular copying function for me simply does not work. I followed all the recommendations that are described in solving copying problems, but this only helps for a while, then copying stops working again. I turned off Bartender, but this also does not help. What else can I do to make the program work?
Let’s get to the bottom of it together. First, can you please do the following procedure:
The following procedure can help if PopClip’s Copy function is not working properly. It removes PopClip from the Accessibility permission list and then adds it again.
- Quit PopClip
- Go to System Settings → Privacy & Security → Accessibility
- In the list, highlight PopClip and then remove it using the “–” (minus) button. (Fully remove it, don’t just uncheck it.)
Remove from the list with minus button
- Use the “+” (plus) button add PopClip again to the list.
I have made this recommendation more than once. This helps for a while but then the problem returns again.
Are there any other recommendations to solve this problem?
I don’t know of any other known issues regarding the copy function not working.
Could you please describe in more detail exactly the nature of the problem using details of exactly what steps you do and what pop clip does and at which point It diverges from the expected behaviour. and also the name of the app that you’re using and the type of text area you are selecting The more information I have that may help me understand what is happening.
