Hello, often when I use the shortcut to select everything, popclip does not open.
Is this normal?
I saw that you added the shortcut, but if it could save me another manipulation.
Thank you for your help.
Is this normal?
Hi, yes that’s right. PopClip only automatically appears on mouse selections, not keyboard selections. You’ll need to manually activate PopClip with its shortcut after doing cmd-A.
Alternatively you could use the Select All extension which will do cmd-A and also activate PopClip.
Another option would be to use a tool like KeyboardMestro or other similar, to make a custom version of cmd-A which will also activate PopClip.
Thank you.
The idea of using the extension that I had not seen is good.
We just have to change our habits
