Alternate search (SHIFT + magnifying glass icon) was working fine for DuckDuckGo. Suddenly it stopped working—now it just responds “Copied” when clicked, and adds the DuckDuckGo link to my clipboard.
Any idea what’s going on? It’s not unique to DuckDuckGo—same exact issue with Bing, etc.
Aaahh, you’ve discovered a bug! Looks like I added this in 2022.12 … I made a small change to several of the built-in actions to work more like extensions do, such that “shift” would cause the action to copy its result to the clipboard with (also for example shift to copy the dictionary definition) … but I forgot that this would clash with the alternate search feature.
Now I’m not sure – revert to old behaviour of shift, or keep the new shift to copy and add alternate search to say the Alt key.
