hi, when i use the extension without any modifier keys it works perfectly but when i am using the shift key to prepend it does not work it just appends. also when using the option key it removes the new line as intended but it also prepends which i think is not intended. could you please look into this extension and update it. its crucial for my workflow.
Thanks for reporting this! I have fixed it now. You’ll need to redownload from:
hello nick, thanks for the prompt reply. again i see the shift and option keys functionality are reversed this time they are doing opposite now but are functional. and also could you please insert a space in between each copies when not doing the line separator so, that it looks natural like a sentence/paragraph.
Thanks for the feedback on the update. I have now swapped the Option and Shift keys. I have also added the Space separator when holding Option.
