Is there any way I can append to the last Drafts note rather than creating a new Draft every time? Similar to the functionality of Prepend/Append to clipboard, but to Drafts instead.
Hi @curtmac01, wlecome to the forum.
The Drafts extension uses Draftsâ own system services. Thise are âCapture to Draftsâ and âCapture to Drafts with Optionsâ. The latter corresponds to the Capture with Panel option in the extension.
I think the panel lets you pick a note to append to; however, Iâm not sure as I donât have Drafts pro to test it properly.
Thanks @nick I got it to work. Albeit it takes a few extra steps to select the draft and then append or prepend it, but it works for what i am trying to do. I thought there might be a shift-click option to append to the last Draft. I took a screenshot of what it looks like in Drafts Pro for others who are interested.
I note that Drafts does have a URL scheme to append text to a draft https://docs.getdrafts.com/docs/automation/urlschemes#append but that it requires specifying the UUID of the draft.
However it also has URL scheme https://docs.getdrafts.com/docs/automation/urlschemes#getcurrentdraft to get current draft UUID so could potentially be used to build an extension to append text to the draft thatâs currently open in the editor. Sound like what you are after?
Yep thatâs exactly what I am looking for. Most of the time I use the normal PopClip feature to send to a new Draft, but it could be nice to have a shift-click (or alternative) option to Append to the current Draft.
OK, so, looking at it, I can see that the getCurrentDraft call requires PopClip to supply its own callback for the reply. It currently does not have a way to do that so we cant use this method ![]()
Bummer. Thanks for looking into it!
Hello there,
I want to highlight a passage in Safari and then click a Popclip extension to call a Drafts action. The Drafts action will append the highlighted text to the last modified Draft.
I got it going in Alfred, where upon a key stroke, Alfred will call the following callback URL:
drafts://x-callback-url/runAction?text={query}&action=Alfred%20Append%20Query
Basically, Alfred calls the Drafts action called âAlfred Append Queryâ (source of this action is here, for those interested)
So, I tried using this
title: Append to Drafts
icon: circle D
url: drafts://x-callback-url/runAction?text=popclip.input.text&action=Alfred%20Append%20Query
But, all it does is append âpopclip.input.textâ instead of my selection. Iâd like to know what is the equivalent to Alfredâs {query}?
Thank you for reading.
I think I am on the right track, yet, the code below still appends the word âqueryâ to Drafts, not the highlighted text. Iâd appreciate help here:
icon: circle D
const query = encodeURIComponent(popclip.input.text)
const url = 'drafts://x-callback-url/runAction?text={query}&action=Alfred Append Query'
popclip.openUrl(url)
Edit: more progress. I think I have to use ${query} and I should use ` instead of â in the const url. Hereâs the new snippets:
icon: circle D
const url = `drafts://x-callback-url/runAction?text=${query}&action=Alfred Append Query`
Now, what I highlighted in Safari gets appended into Drafts BUT, all the spaces are replaced by %20. For example, the text below is what was appended into Drafts:
In%20the%20age%20of%20viral%20hacks%20and%20kitchen
Where did I go wrong?
This encodeURIComponent tripped me up.
Just use
const query = popclip.input.text and I am good to go! Thanks for reading.
Well done figuring it out!
