I have extension using AppleScript which alters behavior depending on pressed modifiers keys (so it uses ‘popclip modifier flags’ inside).
It also uses ‘keystroke’ command inside to control another application. The problem is that currently pressed modifiers are mixed into modifiers I give to ‘keystroke’, so target application gets invalid combination.
I found no easy way to wait until modifier keys are released from inside applescript, so it would be cool if PopClip either:
- wait until modifier keys are released before running script
- provide way to get currently pressed modifiers (not ones which were pressed during action invocation)
Hi
This is what I have cobbled together from looking at previous posts and various google results. It seems to work for me, but I am only checking for the Option key, so you may need to change things up a bit for your purposes.
The script below takes the selected text as the basis of the name of an environment file. If Option is pressed then it adds a “1” to the selected text. The result is then written to iTerm2 as part of a command to source the required environment.
requires: [ text copy ]
applescript: |
on setClipboard(newString)
set the clipboard to newString as string
end setClipboard
use AppleScript version "2.4" -- Yosemite (10.10) or later
use framework "Foundation"
use framework "AppKit"
property NSOptionKeyMask : a reference to 524288 -- 0x80000
property hasOption : false
set modFlags to "{popclip modifier flags}"
set hasOption to ((modFlags div NSOptionKeyMask) mod 2) = 1
set theText to "{popclip text}"
property NSEvent : a reference to current application's NSEvent
on getKeyStatus()
-- Return status of the key - Up or Down
set theFlag to NSEvent's modifierFlags() as integer
set theMask to NSOptionKeyMask
if ((theFlag div theMask) mod 2) = 0 then
set keyStatus to "Up"
else
set keyStatus to "Down"
end if
return keyStatus
end getKeyStatus
delay 1
if hasOption then
set theText to theText & "1"
-- wait for key up
repeat until hasOption is false
set keyStatus to getKeyStatus()
if keyStatus = "Up" then
set hasOption to false
end if
delay 0.1
end repeat
end if
tell application id "com.googlecode.iterm2"
activate
if exists (current window) then
tell current session of (current window)
write text "source " & theText & ".env"
end if
