Here’s a snippet of AppleScript to help parse the {popclip modifier flags}
use AppleScript version "2.4" -- Yosemite (10.10) or later
use framework "Foundation"
use framework "AppKit"
Base for parsing {popclip modifier flags}
see NSxxxxxxxKeyMask Properties for values
Combo Example: option and control
from PopClip returns: 786432
from KeyCodes returns: 786753
- keyCodes is different because it also includes other mask info
such as which keyboard side for each key
-- classes, constants, and enums used
property NSCommandKeyMask : a reference to 1048576 -- 0x100000
property NSAlternateKeyMask : a reference to 524288 -- 0x80000
property NSControlKeyMask : a reference to 262144 -- 0x40000
property NSShiftKeyMask : a reference to 131072 -- 0x20000
property hasCommand : false
property hasOption : false
property hasControl : false
property hasShift : false
property sourceText : ""
property modFlags : 0
-- Example Custom App Options
property useBitShift : true -- set true if hasOption // default true
property addBitValueComment : false -- set true if hasControl // default false
-- if hasShift set both above to false
property firstNotZero : false -- set true if hasShift and hasCommand // default false
-- Get Data from PopClip
set sourceText to "{popclip text}"
set modFlags to "{popclip modifier flags}"
-- Testing in AppleScript without PopClip. Using example values from top
--set modFlags to 786432 -- example value from PopClip
set modFlags to 786753 -- example value from KeyCodes with other BitMasks
my parseKeyMaskOptions()
my parseAppOptionsForFlags()
my logResults()
on parseKeyMaskOptions()
set hasCommand to ((modFlags div NSCommandKeyMask) mod 2) = 1
set hasOption to ((modFlags div NSAlternateKeyMask) mod 2) = 1
set hasControl to ((modFlags div NSControlKeyMask) mod 2) = 1
set hasShift to (((modFlags) div (get NSShiftKeyMask)) mod 2) = 1
end parseKeyMaskOptions
on parseAppOptionsForFlags()
if hasOption then set useBitShift to true
if hasControl then set addBitValueComment to true
if hasShift then
set useBitShift to false
set addBitValueComment to false
if hasCommand then set firstNotZero to true
end if
end parseAppOptionsForFlags
on logResults()
log {"modFlags value is", modFlags}
log {"hasCommand is", hasCommand}
log {"hasOption is", hasOption}
log {"hasControl is", hasControl}
log {"hasShift is", hasShift}
log {"==================Custom App Options Below"}
log {"useBitShift is", useBitShift}
log {"addBitValueComment is", addBitValueComment}
log {"firstNotZero is", firstNotZero}
end logResults
(* RESULTS
(*modFlags value is, 786753*)
(*hasCommand is, false*)
(*hasOption is, true*)
(*hasControl is, true*)
(*hasShift is, false*)
(*==================Custom App Options Below*)
(*useBitShift is, true*)
(*addBitValueComment is, true*)
(*firstNotZero is, false*)
also may view here:
