Hi,
I got the 2024.3(4508) on Ventura/Intel.
The tickbox for autostart on login can’t be activated. Anyone else got this? Any solution available would be nice, thanks.
On recent macOS, this seems to happen if the app is not installed in the /Applications folder. If needed, quit PopClip and move it to /Applications and try again.
In case that deosn’t work, you might need to go into the Open at Login list under Login Items in System Settings, remove any PopClip entries from the list and re-add them manually.
(This is on my list of things to sort out soon…)
Thanks Nick, that worked.
