Hello everyone.
I have a little problem with Easydict and I can’t figure out if it’s from popclip or Easydict or the latest Macos maj. But when I use my plugin, it doesn’t work. Easydict doesn’t receive anything…
Voici mon script :
icon: iconify:simple-icons:easydisct
before: copy
key combo: shift ctrl option command f
Easydict lets you translate either the press paper or the selected text.
I’ve tried to do both, but nothing … If I use directly without Popclip, no problem.
Any ideas?
