Hello,
For some years ago, you added the enhancement in the calculate extension to take in account the format used in the MacOS Pref.
I’ve just seen now that it is no more the case (probably since the re-writting…) : only the formulas written with dot (.) are seen as formulas !
Is it possible to have again calculate extension managing the comma (,) ?
Thank you in advance
Best Regards,
Ange
Versions
PopClip 9911, macOS 12.3
