Compatibility issues between PopClip and WPS Office.
PopClip has a compatibility issue with WPS Office. When I select text, PopClip only appears if I press its keyboard shortcut. After using the shortcut, PopClip appears automatically the next time I select text, but only once. For subsequent selections, I have to use the keyboard shortcut again.
Thank you for reporting this!
I discovered some compatibility issues and have made some amendments which will appear in the next PopClip version – beginning with next beta release.
thx my firend
It’s available now as build 6246 via the beta update channel in the app. If you get a chance to try it, please let me know if it has improved the situation for you.
