Conflict with DeepL
I have the following problem with DeepL:
Whenever I copy text to the clipboard using Cmd-C, the DeepL menu appears, which should only appear after using the standard keyboard shortcut Cmd-CC. The menu also pops up with some mouse actions.
DeepL Support asks if I am using a clipboard-oriented tool. The only tool I can think of is PopClip. I am using DeepL plug-in.
Apple MacOS 5.5 (24F74)
PopClip 2024.12,
DeepL Deskop App 25.7.12287188
In some cases PopClip will send the โŒ˜C shortcut to an app as part of its process of getting the selected text. Your manual โŒ˜C following this will then look like a CC to DeepL if it is quick enough.
Workarounds:
  • You can disable PopClip (either by turning โ€œoffโ€ or excluding just problematic apps) and only activate it with its keyboard shortcut
  • Or set a different keyboard shortcut to activate DeepL
