Create a nested extension structure
How difficult would it be to create a multi-level system? I have a lot of extensions, and it can get a bit unwieldy. I could use about 5 top-level categories with the next level containing the extensions. For example,
Clipboard / basic editing
* Copy
* Cut
* Paste
Text correction & formatting
* Spelling
* Title Case
* Sentence Case
* Capitalize
* Uppercase
* Lowercase
* Formatting
and so on. So, in this case, there would be only 2 icons in the pop-up, with the extensions under these.
I hope this makes sense.
Thank you.
This will be part of the next feature update :+1:
Very happy to hear that! I know it’s a much requested feature.
Great! Thanks so much.
