Custom SF symbols, per-device API tokens and per-app actions
I’d be great if Popclip supported using custom SF symbols; e.g. I’m trying to add an SF symbol with “bookmark” as base, and “badge.eye” as accessory. I know it’s possible to use SVG code with “svg:”, but the icon isn’t scaled the same as when I use “symbol:”. Ideally PopClip would support importing the .svg file that the SF Symbols app exports.
Further, the GoodLinks extension requires setting an API token. The problem is that the iCloud Sync functionality does not seem to treat this token as device-specific, and instead tries to sync it as well - which leads the sync functionality to absurdity, because it’s not possible to use GoodLinks on both devices simultaneously. Therefore PopClip needs to be able to treat specific fields as device-specific instead of trying to sync them.
Lastly: it might be nice to be able to set individual actions to only appear for specific apps, or alternatively, have multiple separate, distinct lists of actions instead of the single unified list currently, for different apps. For browsing the web different actions can be useful than when reading e.g. in GoodLinks or Unread, and it’d be easier to keep the PopClip menu down to a reasonable size when only showing the relevant actions for the active app.
