Hi, I’m selecting a text and choosing DeepL in the PopClip menu, but only the DeepL website is opening, and the translate windows are showing empty.
The selected text is showing in the URL but is not pasting or adding translate windows.
I don’t know if it is a PopClip or DeepL website issue, but I believe you can solve it.
Good idea, you do have this problem if you use the web version in the extension, right now it only supports translation from the source language to the system language, not reverse translation.
Let me think about it, maybe I can update it in a bit.
Hi @dofyyu, I was looking at it today and I could not quite satisfy myself that I could understand everything about the design such that I will be able to support it in future. I will leave the current one which at least is simple for now as I really need to focus on main PopClip app. I hope people can find yours in your repo.
