It is really difficult to convert latex formulas on Mac,does PopClip Extensions have an extension for converting latex to mathml?
I don’t know of one, buy maybe someone out there has made one?
I searched NPM for a library to do this I found this 11-year old one that looks like it might work. I’ll leave it here for now:
Also
Thank you for your reply. I mean, you can select the text with Chinese and latex language, and then convert the latex into mathml. There is already software to achieve this on Windows computers, but I can’t find any other available methods on Mac. Thank you.
I spent a little time looking at it, and it seems pretty tricky. It would be a fairly major project to make an extension like this. So I will not be able to put something together quickly like I sometimes can.
This is indeed difficult, but this function has been implemented in the win system. Thank you for reading this.
This is an action written by a person, it must be used with the software Quicker
action
