Thank you so much for trying solving new macOS problems! I’m having a trouble with Bitly: when trying to install the new version it appears a message saying “Impossible to install the extension”. Here’s a screenshot:
iMac 27" 2017
macOS 12.0.1
iMac 27" 2017
macOS 12.0.1
Hi Andrea, thanks for reporting it. Can you confirm also which version of PopClip you are running there as well (including the number in the brackets at the end - as shown in the PopClip prefs)?
PopClip version: 2021.10 (1003543)
Ahhh - right, what you need to do is grab PopClip 2021.11 and then it should work fine.
You should find it available to install here.
(I didn’t make it clear enough in the post that there is a new version of PopClip to install. Also my error message was supposed to say “you need to update PopClip” but in 2021.10, the error message says this instead. (So it’s an error with the error…))
Thank you, now it’s working fine!!
