dofyyu
#1
I have another question.
I installed PopClip by App Store, and I install it again by SetApp for test, then I have two PopClip app.
I deleted the SetApp one, and now my extensions have gone and can not install new extension again.
btw, my extension’s extName is popclipextz
nick
#2
This is all quite new so I['m not sure exactly. But I recommend:
- Quit any PopClip that is running
- Delete all copies fo PopClip (from /Applications and from /Applications/Setapp and any other copies you may have (e.g. in Downloads folder)
- Finally reinstall just one copy of PopClip (either Mac App Store or Setapp)
See if that helps and let me know. If not we can then dig in further.
dofyyu
#3
Cleaned up a bit and problem solved.
