Generator QR code is very needed
Thank
If you are running macOS Monterey. You can us a shortcut and call it with an extension snippet.
The shortcut is a simple one like this → Shortcuts
and your snippet would look like this
# popclip Generate QR Code
requirements: [url]
icon: square q
shortcut name: QR Code
A video showing this working is here https://cln.sh/Kajrya
QR code Below points to
A Note - for some reason the action says it fails but it totally worked!
This is awesome Jay thanks I’ll see if I can figure out why it is failing.
Sorry for the Dumb Question, can you tell me a couple of use cases. It seems to be very useful, but I can’t think of where I can use this
@dhanya One use is transferring URLs or other information to other devices. Say you have a web URL you want to open on a phone, you can display the QR code for it and scan in on the phone.
