I run macOS Shortcut from PopClip, but I want to move it to dedicated folder in shortcuts application (f.ex. Dokuwiki).
How should I setup Shortcut name in YAML - format Dokuwiki/Shortcut-name doesn’t work for me.
Just use Shortcut-name. Being in a folder doesn’t affect the name as seen by PopCip.
OK
I’ve seen in other program the list of shortcuts divided in groups with names from folders, that why I asked.
BTW
I use that Shortcut in my as the solution for UI to select some option and back to PopClip
Thx
