How do I disable PopClip on Shift+Click?
PopClip appears when I Shift+click.
Is there a way to stop it?
Hi, thanks for the post and welcome to the forum.
The shift+click behaviour is hard coded in and there isn’t a way to disable it.
However, if it’s just in a particular app that this is causing a problem, you could add that app to the excluded apps list. (Still use PopClip there with the keyboard shortcut.)
Thanks, that solved my problem.
