Identifying issues with pop clip not working [solved]
Hello I’m hoping someone can give me some guidance to t-shooting issues that have “popped” up with pop clip. I have macOS 26.2 (beta 3) and have been noticing even before that version that pop clip stops being able to function properly. The pop clip bar will come up when I double click to want to paste or when Im highlighting something to cut/copy. I notice that I click the copy button for example then I hear a “thunk” sound and it doesnt copy. If I right click and use the menu it will copy correctly. I’ll also notice a slight delay when I click the copy or the paste button. Some of the fixes I have tried have been resetting the privacy settings (sometimes works), quitting restarting pop clip, or restarting my box. I wonder too if it maybe an app that I might have installed conflicting with it somehow. Is there a way to chase this down, I totally love pop clip in my workflow.
Hi, I don’t think it’s an issue with 26.2 beta 3 sepeicially because I have that and it’s working OK. Your theory of an incompatibility with another app is a good area to investigate. I recommend to quit all other background apps and see if the issue persists.
Hello thanks for the response. I did some more hunting in the forums and found out it was BetterMouse causing my issues ( PopClip "Copy" not working - #7 by nello ). I added popclip to the exceptions list of BetterMouse and it fixed my issues.
