I’ve noticed a compatibility problem between PopClip and Droppy. It seems that when Droppy is launched and PopClip is used, this causes problems. For example, when I try to use the extension with ChatGPT, the text doesn’t stick under the selection as before. Similarly, with EasyDict, the selected text does not arrive in the translation application.
I’ve also reported this problem on the Droppy assistant.
I’m running Droppy in trial mode with all the default settings. Everything seems to be working like normal for me with PopClip and Droppy running. Could you please give a more detailed example of an issue that I can recreate with exact steps? Are there any particular settings in Droppy that cause the problem? Also, including exactly what PopClip extension you are using, for example. (We have a couple of EasyDict ones on the forum that work quite differently.) And is it the ChatGPT website extension?
Concerning droppy, I’ve just found the option that’s causing trouble, it’s Basket, it’s the only option activated for me. And by trying to deactivate it, popclip works properly.
So I think the conflict comes more from Droppy.
But maybe you’ll have some ideas on how to improve it.
