Installation requiring 'Full device control and data access'
Just purchased license for Mac. Currently on Golden Gate 27.2.1 (26B7131). According to the installation guide PopClip should ‘request Accessibility Access’. However, the dialog box is requesting ‘Full device control and data access’. Can you explain why? Obviously, I’m reluctant to allow this.
Hello — Thanks for the question! I need to update the user guide. The old “Accessibility” setting was renamed to “Device Control and Data Access” in macOS 27. It’s the exact same thing though. Just a different name for it.
It’s fundamental to how PopClip works that it needs to access the contents of other apps. That is to say, it detects when you select text and reads the selected text. To do this, PopClip uses something called the Accessibility API. Without enabling this access, it is impossible for PopClip to work.
PopClip does not access any data from your apps or your Mac except for the text you select. And it also doesn’t report any of that text back via the internet (neither to me or anywhere else).
See Privacy Policy: https://www.popclip.app/privacy
If you have any further questions or concerns, please don’t hesitate to follow up with them, and I will do my best to explain further.
OK, understood, thanks
