I searched and found that I can set up automatic replication, but I don’t know how to set up other extensions to make it run automatically.
Can you describe in more detail what you mean by run automatically? What conditions would trigger the automatic running?
For example, if I set up an extension to highlight text, it can be automatically highlighted when I select text, instead of selecting the extension icon to perform this action. What I mean is that I can specify an extension to run automatically. Of course, if I can set it to run The conditions would be better, for example, this extension can only be automatically run under specific applications. This is an idea of mine.
That’s an intesesting idea, thanks. It’s not possible to make PopClip do this as it stands.
