I am sure this has been asked, but I have looked.
Extensions are stored in a folder: ~/Library/Application Support/PopClip/Extensions
So, if you want to you can back up the contents of this folder.
Instead of backing up, I would like to transfer my entire Popclip setup, i. e. setting, extensions etc. to another Mac. What should I transfer, what not, if any?
Thank you!
Transfer extensions and settings to a different Mac
Whilst there is no built in import/export or sync, you can manually copy
your existing extensions and settings to a different Mac by copying across the following:
Extensions folder:
Preferences file:
~/Library/Preferences/com.pilotmoon.popclip.plist
Best do that while PopClip is not running on the target Mac.
Expected that - thanks for the confirmation!
