Is there a way to exclude web pages similar to the way that you can exclude apps in settings? I want to stop popclip coming up when I play on chess.com.
Hi, @stationagent1, welcome to the forum. Excluding web pages is currently not possible. But a lot of people have asked for it and it is high on my roadmap.
The best you can do for now is temporarily turn off PopClip when you are on that site.
By the way is there a particular issue you are having with PopClip on chess.com? I play on that site too but have never noticed PopClip appearing when I play. What version of PopClip are you using and what browser do you use?
BetterTouchTool has the ability to trigger actions based on an current URL(Change BTT behavior based on website? - #7 by rishifter - Discussion & Questions - BetterTouchTool Community or “Did Open URL” trigger), so you can run this shell command to disable PopClip:
defaults write com.pilotmoon.popclip.plist PopEnabled -bool false
And so to reenable:
defaults write com.pilotmoon.popclip.plist PopEnabled -bool true
+1 for this! My use case is in email newsletter tools (specifically Omnisend, but I’m sure it affects others) - several of these tools have text editors that will pop up some quick text formatting options when you highlight text, and PopClip interferes with that.
Toggling it on and off is not the end of the world, but would be a nice feature ![]()
