JS - Async/Await help
My code does not wait to return the result from an API call.
I need help on fixing the async/await syntax, can somebody help me?
const axios = require("axios");
async function getRate() {
    const response = await axios.get('https://open.er-api.com/v6/latest/USD');
    print(response.data.rates.EUR)
    return response.data.rates.EUR;
return await getRate()
That’s the result I get from the terminal:
2023-10-13 12:17:12.242 PopClip[9569:350202] [INFO] main: PopClip main() called
PopClip JavaScript Test Harness (apiCall.js)
require(axios): Loading /Applications/PopClip.app/Contents/Resources/js_bundles/axios.js.lzfse
XHR: Starting GET request for url 'https://open.er-api.com/v6/latest/USD' with responseType '' and headers:
Accept: application/json, text/plain, */*
XHR: status 200 (no error), headers:
content-type: application/json
access-control-allow-origin: *
last-modified: Fri, 13 Oct 2023 14:11:03 GMT
nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
content-encoding: br
server: cloudflare
report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=iyiL7BhXufwpO%2Fm%2BuTIhlWkt8xyuaKYVodvWqKy0pUQnSIaYH0Erv3Amq%2F7Q9MFzjvaCd55xgY%2BBrUf4G5txiaTiM85MaIig17TjYviOxoT91BMz9qJjxVIZeExbIed9zdZ%2BJj8zET78EnSwoQ%3D%3D"}],"group":"cf-nel","max_age":604800}
cf-cache-status: HIT
cache-control: public, max-age=3600
date: Fri, 13 Oct 2023 14:54:19 GMT
x-content-type-options: NOSNIFF
cf-ray: 81586acbff9b2622-GIG
vary: Accept-Encoding
x-frame-options: SAMEORIGIN
XHR: response length: 2908, mimetype: application/json (text), charset: (null), response:
{"result":"success","provider":"https://www.exchangerate-api.com","documentation":"https://www.exchangerate-api.com/docs/free","terms_of_use":"https://www.exchangerate-api.com/terms","time_last_update_unix":1697155351,"time_last_update_utc":"Fri, 13 Oct 2023 00:02:31 +0000","time_next_update_unix":1697243021,"time_next_update_utc":"Sat, 14 Oct 2023 00:23:41 +0000","time_eol_unix":0,"base_code":"USD","rates":{"USD":1,"AED":3.6725,"AFN":75.550889,"ALL":99.742392,"AMD":397.055033,"ANG":1.79,"AOA":835.619699,"ARS":350.03,"AUD":1.577862,"AWG":1.79,"AZN":1.702093,"BAM":1.851479,"BBD":2,"BDT":110.287519,"BGN":1.850435,"BHD":0.376,"BIF":2831.034802,"BMD":1,"BND":1.366971,"BOB":6.92028,"BRL":5.048046,"BSD":1,"BTN":83.294779,"BWP":13.716816,"BYN":3.293651,"BZD":2,"CAD":1.365413,"CDF":2479.851446,"CHF":0.905719,"CLP":925.311747,"CNY":7.305164,"COP":4230.677317,"CRC":534.190708,"CUP":24,"CVE":104.381965,"CZK":23.266639,"DJF":177.721,"DKK":7.06893,"DOP":56.779044,"DZD":137.369415,"EGP":30.90266,"ERN":15,"ETB":55.792174,"EUR":0.94647,"FJD":2.266273,"FKP":0.818756,"FOK":7.062342,"GBP":0.818761,"GEL":2.69016,"GGP":0.818756,"GHS":11.905216,"GIP":0.818756,"GMD":65.826637,"GNF":8591.219145,"GTQ":7.841103,"GYD":209.364355,"HKD":7.822635,"HNL":24.659914,"HRK":7.132507,"HTG":134.675747,"HUF":365.736498,"IDR":15707.797765,"ILS":3.963366,"IMP":0.818756,"INR":83.294887,"IQD":1308.757634,"IRR":41921.710555,"ISK":137.930564,"JEP":0.818756,"JMD":155.249347,"JOD":0.709,"JPY":149.567557,"KES":149.0905,"KGS":88.758913,"KHR":4126.029195,"KID":1.575229,"KMF":465.719498,"KRW":1345.213848,"KWD":0.309237,"KYD":0.833333,"KZT":475.732016,"LAK":20521.561238,"LBP":15000,"LKR":323.260212,"LRD":189.740852,"LSL":18.977655,"LYD":4.887352,"MAD":10.240551,"MDL":18.14819,"MGA":4526.359547,"MKD":58.15111,"MMK":2099.599851,"MNT":3464.000023,"MOP":8.057551,"MRU":38.4406,"MUR":44.188424,"MVR":15.435283,"MWK":1165.118935,"MXN":17.954467,"MYR":4.714381,"MZN":63.89939,"NAD":18.977655,"NGN":766.16673,"NIO":36.589402,"NOK":10.941421,"NPR":133.271646,"NZD":1.684667,"OMR":0.384497,"PAB":1,"PEN":3.834274,"PGK":3.693217,"PHP":56.712268,"PKR":279.49264,"PLN":4.288736,"PYG":7333.738937,"QAR":3.64,"RON":4.68142,"RSD":110.390702,"RUB":97.600283,"RWF":1246.823377,"SAR":3.75,"SBD":8.515787,"SCR":13.632928,"SDG":559.94472,"SEK":10.969705,"SGD":1.366468,"SHP":0.818756,"SLE":22.593073,"SLL":22593.073057,"SOS":572.101212,"SRD":38.553905,"SSP":1020.951271,"STN":23.192837,"SYP":12955.364871,"SZL":18.977655,"THB":36.33494,"TJS":10.93555,"TMT":3.500833,"TND":3.173806,"TOP":2.351888,"TRY":27.772441,"TTD":6.768636,"TVD":1.575229,"TWD":32.174167,"TZS":2508.768888,"UAH":36.412402,"UGX":3759.39122,"UYU":39.920175,"UZS":12269.438563,"VES":34.9001,"VND":24439.07751,"VUV":121.829619,"WST":2.763914,"XAF":620.95933,"XCD":2.7,"XDR":0.759568,"XOF":620.95933,"XPF":112.965208,"YER":250.398742,"ZAR":18.98816,"ZMW":21.535855,"ZWL":5643.037096}}
0.94647
Done: success: <no output text>
You code looks good and it looks like it worked fine. I can see the JSON result from the API printed in the console output.
Thanks NIck, but how can I return a value from the json to the main function?
My file is returning <no output text>
Ah, I see. When you run code in the test harness, it looks like PopClip isn’t picking up the return value properly when there is an async call.
That seems to be a bug with the test harness itself; my apologies.
But if you put some prints in the code like this:
print("starting");
const rate = await getRate();
print("done, got rate", rate);
…you’ll see that the async call is working.
The test harness is very basic and could be much improved. You’re the first person other than me I’m aware of using it! So I’m happy about that.
I suggest using a print statement to verify your code while running the harness.
Hi @bernardogomel — I’ve now made improvements to the test harness in the latest beta, Build 4610.
I’ve also improved the documentation at JavaScript environment — PopClip Developer
