Make CAPS and keep selected
Hi, I work for a newspaper and often have to upper/lower case words and phrases. It would be handy if there was a way to capitalise, say “KEVIN WINTER/GETTY IMAGES” and then keep it selected so that I can Cmd-X or Cmd-C to copy and paste. Is that possible please Nick? Could the function be added to settings, please?
Best wishes
Will, Colchester, UK
Hi @WillieB, welcome to the forum.
Use the existing Uppercase extension for this. It leaves the upper case text on the clipboard for you as well as changing the text. So you don’t have to press copy manually.
You can also hold Shift when you operate it to just copy the uppercased text and not transform the selected text (works for all text transformation extensions).
Example with holding shift:
CleanShot 2026-04-18 at 07.29.09
Many thanks. I didn’t guess it would be that easy! PopClip has really helped me in smoothing my workflow.
