I finally got around to doing something with my kludgy NotePlan clipper extensions that have limited formatting functionality. Instead of rewriting the python-based Daily_NotePlan and Clip2NotePlan extensions, I went for the simplicity of snippets.
Edit the below as needed, it should be pretty straightforward using the NotePlan x-callback docs.
Updated 2022-02-09: cleaner code, better headers for non-html sources
Clip to Daily Note
# PopClip - NotePlan Daily Note
icon: symbol:calendar.badge.plus
capture html: true
let clipping = popclip.input.markdown
if (popclip.context.browserUrl.length > 0) {
let title = encodeURIComponent(popclip.context.browserTitle)
clipping = `# ${title}\n` + clipping
clipping += `\n[${popclip.context.browserTitle}](${popclip.context.browserUrl})\n#clipped`
} else {
let fname = popclip.input.markdown.split(' ').slice(0, 7).join(' ') + `…`
clipping = `# ` + fname + `\n` + clipping + `\n#clipped`
clipping = encodeURIComponent(clipping)
popclip.openUrl(`noteplan://x-callback-url/addText?noteDate=today&text=${clipping}&mode=append&openNote=yes`)
Clip to New Note
# PopClip - NotePlan New Note
icon: symbol:asterisk
capture html: true
popclip.openUrl(`noteplan://x-callback-url/addNote?noteTitle=${title}&text=${clipping}&openNote=yes`)
} else {
popclip.openUrl(`noteplan://x-callback-url/addNote?text=${clipping}&openNote=yes`)
