One extension with two buttons/icons?
Is it possible to bundle two buttons/icons with one popclip extension? I’m trying to build an extension with two main functionalities, and I’d like to avoid creating two separate extensions if possible.
Yes, an extension can have two or more actions. This is accomplished by including an actions array in the config.
Here’s an example snippet:
# PopClip JS + Multi-Action Example
name: Markdown Formatting
requirements: [text, paste]
actions:
- title: Markdown Bold
  icon: circle filled B
  javascript: popclip.pasteText('**' + popclip.input.text + '**')
- title: Markdown Italic
  icon: circle filled I
  javascript: popclip.pasteText('*' + popclip.input.text + '*')
Take a look at the actions documentation. If you have any specific questions, feel free to ask.
Thank you Nick!
I completed the extension and it works perfectly.
Can I promote it in PopClip Extensions - PopClip Forum? The extension activates an app that I built, and I want to make sure this doesn’t violate the policy of the forum.
Yes, that’s fine. Happy for you to post about your app & PopClip extension.
Awesome, thanks for confirming
