Perplexity is a new AI-based search tool using OpenAI technology. In many respects it is an extremely strong competitor to Google.
Icon: square P
url: https://www.perplexity.ai/?q=***
#end
Icon: square P
#end
Great stuff, and interesting the use of the end tag. I did consider end tag as a formal requirement in the snippet spec, but decided against it in the end.
in my case, it gives an ‘invalid YAML’
After removing the
requirements:[ ]
line, it works fine.
This is brilliant thank you ![]()
I expected a ready extension in the library but this works for me!
One question: did you find a way to invoke this with ‘copilot’ activated on Perplexity?
That’s it
Icon: square P
url: https://www.perplexity.ai/?q=***&copilot=true
#end
You could also use icon: iconify:simple-icons:perplexity
could this be tweaked to use the app’s url scheme? i’m dense
url: perplexity://search?q=***
#end
Looks good to me. Does it work?
Thank you.
