You can now set a system-wide keyboard shortcut to trigger PopClip to appear.
Option to automatically set the dark/light appearance of the PopClip bar to match the system.
Made the “small” popup size a little more compact.
Improved compatibility with Electron-based apps such as Discord and VS Code.
And bug fixes, of course.
If PopClip releases had code-names, this one would be called “Iceberg” because there’s not much to see on the surface, but there’s a lot going on underneath. This release also includes big improvements to the system for creating your own extensions, including running Shortcuts on macOS Monterey. Look out for documentation coming soon to the PopClip Extensions GitHub repo, as well as how-to guides on the new PopClip Forum — to which, having read to the bottom of the release notes, you are specially invited. -Nick
That’s the quick summary. There’s lots to unpack with this one, and I will be sharing more info here in the forum.
The keyboard shortcut probably is something you might want to try out. It’s been asked for a lot over the years, but until now there has only been the AppleScript trigger. Have a go with it and let me know how you get on.
The new keyboard shortcut is going to make the world a much, much better place! Great idea!
Now we can activate PopClip from the keyboard and navigate through the actions with arrow keys… Something I find myself wanting to do pretty much every day.
Working great so far (on Intel 12.0.1).
Cheers @kelpie. If nothing else, it can be handy for if you are trying to get PopClip to appear with the mouse and it is refusing.
But mainly it has been asked for by people who prefer to do their text editing with the keyboard. So you can select the text with ⇧+arrows, then activate PopClip, select action with arrow keys, and hit enter – all without taking hands off keyboard.
The keyboard (and AppleScript) trigger also works even when PopClip is turned off, or if the app is in PopClip’s excluded apps list. So it adds a little extra flexibility there too.
