PopClip 2024.5 is now available on the PopClip website and on Setapp.
What’s new
2024.5.2:
- Bug fixes.
2024.5.1:
- Fixed crash at launch that affected some users.
2024.5:
This is a general housekeeping update with various fixes to keep PopClip running smoothly. Thanks to everyone who has reported issues and tested betas to help make PopClip better.
The most notable fixes are:
- Fixed “Start at Login” checkbox not working in some circumstances.
- Fixed Standlone edition not recognising Mac App Store receipt in some circumstances.
See Beta Version History for details about every change in this version.
This release also includes a couple of new features for extensions developers that you can read about in Developer Changelog.
Version information
- App: PopClip, https://www.popclip.app/
- Version: 2024.5.2 (4615)
- Release date: June 5, 2024
- Requirements: macOS version 10.15.7 and above; Apple Silicon or Intel processor.
Updating your existing app
Mac App Store Edition
This update is not available via the Mac App Store. As I announced in March, PopClip has left the Mac App Store. To receive this update, please follow the migration instructions.
Standalone Edition
You can trigger an update by un-checking and re-checking the Check for Updates checkbox.
Setapp Edition
The update will be automatically installed by Setapp. You can manually trigger the update by clicking “Check for Updates…” in the Setapp menu.
Homebrew
If you installed PopClip via homebrew, you can run brew upgrade popclip.
