PopClip action popup does not appear in Telegram when using a Supergroup with Topics
Summary
PopClip’s action popup does not appear when selecting text inside a Telegram supergroup
that has Topics enabled (forum mode).
Environment
  • PopClip version: 2025.9.2 (5155; 27 Oct 2025)
  • Edition: Standalone
  • macOS version: 15.7.3 (24G419)
  • Telegram version: 6.7.8
Steps to Reproduce
  1. Open Telegram on macOS.
  2. Navigate to a Supergroup that has Topics (forum mode) enabled.
  3. Enter any Topic thread inside the supergroup.
  4. Select any text in a message.
Expected Behavior
The PopClip action popup should appear after selecting text, as it does in normal chats.
Actual Behavior
The PopClip action popup does not appear. No popup is shown at all.
Additional Notes
  • The issue is specific to Supergroups with Topics enabled.
  • PopClip works correctly in regular Telegram chats and channels.
Workaround
None found.
