I updated it last night and it became like this.
Well, that’s not good! Thanks for reporting.
What actions are those, that are showing? And what’s your macOS version?
Also do you know which previous version you updated from, that was working ok?
macOS Sonoma 14.0(23A339)
4183 is working fine
the icon showing only when the cursor was on it
Thanks for the further info, that will be helpful. I will investigate.
EDIT: It’s reproducible on my machine (phew), so I should be able to get to the bottom of it soon…
It should now be fixed in Build 4220 — please let me know.
it’s working fine now, thank you!
