I try to select this check box ,But still can not selected this, Any one have the same issue ? and know how to fix this ? My mac os version is: 14.3.1
Usually to fix this problem:
Quit PopClip.
Move the PopClip application to the
/Applicationsfolder, if it is not there already -
Go to System Settings → Login Items
Remove all entries for PopClip from the Open at Login list
Manually add PopClip back to the list.
