Popclip extension for Scrivener
Hi,
I am in BigSur 11.7.10 (20G1427) and Scrivener 3.3.6.
PopClip extension does not send the selected text to Scrivener, i tried all the options.
It is working with SnippetsLab and EagleFiler extension but not with Scrivener.
I realy need it working with Scrivener.
Thanks
correct me if i am wrong but isn’t popclip just invoking a built-in scrivener service here?
so does the service work? is the service turned on? check system preferences → keyboard → shortcuts → services
Hello,
Thanks for you reply you are correct all Scrivener services are selected but no one works…
Now I will report to Scrivener support.
Thanks
