Hi all! PopClip seems like a great application, so i wanted to test out the trial before deciding to make the purchase. However, after unzipping the downloaded file, PopClip.app won’t open for me. Well, in fact, it will open (since i do see the process running in the Activity Manager) but nothing happens. The interface of the application just doesn’t launch and i also don’t get any error message in macOS. I tried 2 different versions - the 2022.12 release and the PopClip Build 4129 release. Purchasing via the App Store is not really a solution at this time, since I’d like to try the application out for a bit first. Any idea what might be the problem here and how I can fix it? Thanks for your help!
Not sure, but I’ve heard one or two people say the same thing happened over the years but I seem to remember it was transitory. Dare I suggest a reboot?
Also sometimes there are interactions with menu bar organiser apps like Bartender, Vanilla and such. Could it be that?
Thanks so much for your response! I tried quitting all menu bar organiser (and other) apps and rebooted multiple times. Unfortunately, the problem still persists.
