Popclip not working in intelliJ Terminal
Hi,
Any idea how to debug ?
Popclip is working in intelliJ Editor but not working in terminal.
I am using keyboard shortcut!
I don’t currently jave any JetBrains apps installed to test. One thing that you can do is option(⌥)-click the PopClip menu bar icon to reveal a debug window. Then record a short screen video (with QuickTime Player or similar) showing the fault and with the debug window showing. Then send me the vid - you can use https://www.dropbox.com/request/QZit2LMzPZsQc09tjBsi
Actually I changed the terminal settings in intelliJ and now it is working!
Great! Could you post what the settings change you made was? It may be helpful for other people who search for the same problem and find this thread.
