Hi there!
Popclip randomly appears and disappear while using pdf expert 3. I have a MacBook pro m1, mac os ventura 13.01 and the latest versions of both popclip and pdf expert
I recommend setting a keyboard shortcut in PopClip so you can activate it in apps where it doesn’t appear, e.g. PDF Expert 3.
(PDF Expert 3 has been the most troublesome app. every few months they change something to break PopClip!)
is it possible to activate a shortcut to trigger an extension? I heavily rely on scrivener
No, only to trigger PopClip itself, not for individual extensions.
Download and double click this file. It will reconfigure PopClip, and hopefully will recognise your PDF Expert properly.
Mac App Store and Standalone editions (v2022.12):
4069-002.popclipconfig (639 Bytes)
Setapp edition (v2023.1):
4127-001.popclipconfig (639 Bytes)
The config file also fixed the problem for me. Thank you!
Apple M1 Pro
Ventura 13.2.1 (22D68)
PDF Expert Version 3.0.36 (902)
Thanks for letting me know! I’ve also added a link to a config file for the current Setapp version.
