I am using Popclip via SetApp. My activity monitor shows it is running but it is not working. I cannot find it in my menu bar. I have stopped running Bartender so that is not the problem. I have tried killing PopClip in the activity monitor and then reactivating it but still nothing. Any suggestions?
Usually when this symtom happens it is because of Bartender or a similar app.
Hoever as you are not running Bartender β or any similar app? β I donβt have a ready answer.
Can you start with a clean reinstall as follows:
Quit PopClip, delete it.
Clean the prefs by typing in Terminal:
defaults delete com.pilotmoon.popclip
(warning - you will need to reinstall extensions after this) -
Restart Mac.
Reinstall PopClip
