Those who use Devonthink may find this to be of interest - simple but very useful if you use Annotations in Devonthink:
Hello @nick
I am trying to modify this to execute two key sequences so that I can highlight the text before creating a quote. Why do I get an Invalid YAML error here?
icon: square DQ
popclip.pressKey('L', util.constant.MODIFIER_SHIFT|util.constant.MODIFIER_CTRL)
popclip.pressKey('Q', util.constant.MODIFIER_CTRL|util.constant.MODIFIER_COMMAND|util.constant.MODIFIER_SHIFT)
required apps: [com.devon-technologies.think3]
#end
It’s most likely the two spaces indent before the word javascript. Is should be on the same indentation as it sibling keys.
YAML is very sensitive to leading white space.
Many thanks
That was it- plus CONTROL needs to be spelled fully
This works:
icon: square DQ
popclip.pressKey('L', util.constant.MODIFIER_SHIFT|util.constant.MODIFIER_COMMAND)
popclip.pressKey('Q', util.constant.MODIFIER_CONTROL|util.constant.MODIFIER_COMMAND|util.constant.MODIFIER_SHIFT)
#end
@rkaplan, you may be interested to know that in PopClip 2022.5 the above snippet can now be rewritten as:
icon: square DQ
key combos: [command shift L, control command shift Q]
or staying in JS, the same syntax can now be used:
icon: square DQ
popclip.pressKey('command shift L')
popclip.pressKey('control command shift Q')
Very nice - thank you for the follow-up @nick
