@nick Good news, after upgrading to 26.1, popclip is working normally! No more lag
Ah, good! Thank you for the update
The issue still seems to occur intermittently. Iām not sure of the exact cause, but it often happens after I close my laptop lid and leave it for several hours. The only solution that resolves the stuck state is to restart the computer; force-quitting Helium and PopClip does not fix the problem.
@nick I am having this happen, only with the latest version of popclip. Previous versions do not have any issues. It also does not seem to be all things that break. Only search is ābrokenā (takes a very long time to process for me)
Hi there. This is a bug with the browser hanging when asked by PopClip to execute an AppleScript. It may be that reinstalling Helium and/or restarting the Mac will fix it. If not, you can enter the above Terminal command to work around it. (Thereāll be a slight degradation of PopClip functionality, but in general you wonāt notice it unless you use Shift to open background tabs or use incognito or private tabs a lot.)
Iāve been having tis issue for some months now too. Just isolated it to Helium browser myself. Usually it fixes itself after a reboot, but randomly does it again!
Your Terminal fix seems to have fixed the issue though. Will keep an eye on it!
