PopClip to Obsidian
What is the status of an extension to copy text into Obsidian? I know there has been one in the past (from searching this forum) but I don’t see anything currently listed. I would find it extremely useful. At least PopClip does seem to work fine inside Obsidian, which I really appreciate.
This is the current state-of-the-art for Obsidian as far as I am aware: Clip selection to Obsidian
You have to install a special extension for Obsidian mentioned at the start of the thread, then install one of the snippets posted in the thread: this one
I will look into making this an “official” PopClip extension soon since it seems to be established as working well. I had not done it yet because it requires that extra install step, but I guess it’s not too big a hurdle.
Here it is: Obsidian — PopClip Extensions
Please read the README carefully for the preparation steps.
WOW! That was fast!
I just installed it, following your directions precisely, and it worked first try!!! Exactly what I was looking for. Thank you so much! I’ve used it a few times already, and so far no issues.
Thank you again!
Bob
Great! Thanks for the positive feedback.
