Hi
Having problems with PopClip on MacOS 27. Using PopClip 2026.8.1 (6221; 7 Sep 2026), it doesn’t seem to trigger. Infact sometimes the right mouse click needs 2 or 3 attempts. No issues with Tahoe.
Thanks
Hi
Thanks
Hi @rwnash, welcome to the forum ![]()
PopClip has been run by thousands of users on macOS 27 betas for several months and there are no known issues.
That said, it’s common for there to be glitches right after an OS upgrade. I recommend giving the machine a full restart and see if anything changes.
If you’re still having trouble after a restart, let me know and we can dig more into the specific details.
Hi
Thank you for the prompt reply. Although I had reboot previously, PopClip is now running like a Champ!
Thank you
