@nick first of all, thank you for the response. This is a dealbreaker for me, as I’m seeking the fastest solution that allows me to easily translate any selected text on my computer (web, mail client, files, …).
Is there any workaround solution in the form of another extension that you would recommend?
I don’t have anything else pre-made myself, but since extensions are fully customizable you can achieve anything you want. You might find some success with custommizing some of the OpenAI extensions that have been posted on the forum.
I want to put out some resources to make this easier but until then I’ll just point you in that direction.
